problem with xmltype
ciabalaba
Does anyone know of any problem with xmltypes?
It seems that pl/sql consider xmltypes as clobs,
and crashes the Oracle instance on call of table like this
create or replace type mex_type as object
( livello_svd varchar2(3),
execution_id number(3),
pkg varchar2(40),
func_proc varchar2(40),
tabella varchar2(40),
mex varchar2(200),
xml_doc xmltype,
data date,
livello number(2)
create table DWH_MF2_VERIFICHE
of MF2.MEX_TYPE
if you do a "Query data " on this table you get
select * from DWH_MF2_VERIFICHE
but generates an error on plsql that needs instead
select ..., t.xml_doc.getclobval() aa from DWH_MF2_VERIFICHE t
Did anybody have any problem like this?
maybe we need some recent oci's??
Thank you
riccardo
It works okay for me, but we have had some more reports about xmltype issues. It is most likely related to a specific client/server/platform version.
