Problem with test window
ScottMattes
I have a long running Stored Procedure and every time it gets to the end I see
- the Commit/Rollback buttons become active
- then when I expect PLSD to be getting the DBMS_OUTPUT output I get 'end of file and communications channel' and 'not connected to oracle' and NO output
Is this a known problem (Oracle or PLSD) and is there a work around?
Thank you.
ORA-03113 usually means that the Oracle Server process for the current session has crashed. Can you check if a user trace dump file exist on the database server that corresponds to this ORA-03113 error? Usually you will see an ORA-00600 or ORA-07445 error here, with some error codes that may help us find the cause of the problem. If it does, can you send it to me?
There was no dump created, sorry.
I did get the exact same two msgs, 3113 followed by not connected to Oracle, in a SQL Window and I am wondering if it is some sort of timeout problem. The SQL Window had the first 200 rows displayed in the result grid and I hadn't been back to that window in quite a while. When I saw that there were more rows I clicked the 'get them all' button and immediately got the two msgs.
To obtain some more diagnostic information, can you modify the shortcut and add the debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" debug
OK, I'll try that as I leave for home this afternoon. I won't be able to send before the 16th though, we are going for a sonogram Tues and I want to be there so my travel week doesn't start until Wed.
