Problem with Schema having a Table with the Same Name as the Schema
Quantum
If you have a schema which has a table with the same name as the schema, then executing a procedure will fail if you qualify the procedure with the schema name. Execution is successful only after the table is dropped.
This is what I get:
KT@ETL> select * from tab;
TNAME TABTYPE
KT TABLE
TEST TABLE
KT@ETL> exec kt.salrange (2000, 2500);
begin kt.salrange (2000, 2500); end;
ORA-06550: line 1, column 10:
PLS-00302: component 'SALRANGE' must be declared
ORA-06550: line 1, column 7:
PL/SQL: Statement ignored
KT@ETL> drop table kt;
Table dropped
Execution is successful and data is displayed
This symptom is related the one I described in the post:
Auto complete for tables are not happening when we querying other schema objects
