I'm using the last version and found a bug with pl/sql beautifier.
I've a table with a lot of fields and I'm executing an insert statement via
EXECUTE IMMEDIATE 'xxx' USING ;
The problem is that I've many variables and when I try to format the code via beautifier it isnt respecting my "Right Margim setting" and putting all the variables in the same line.
Try to format the code bellow:
create or replace procedure TESTE IS
COD_VERBADISTRIBUIHOJE NUMBER;
EXECUTE IMMEDIATE 'SELECT * FROM TESTE'
USING COD_VERBADISTRIBUIHOJE,
COD_VERBADISTRIBUIHOJE;
IF SYSDATE = SYSDATE THEN
NULL;
ELSE
NULL;
END IF;
end TESTE;
