Hi there,
we have a serious problem with PL-SQL Developer (8.0.1.1502) and Direct Oracle Access (4.0.7). We use Oracle 10.2.0.4.0.
We use Oracle Objects with inheritance. If a pointer/varchar, etc. is used in the hierarchy the fields in the last object in the hierarchy are corrupt.
In our example the Datefield has invalid values, it seems that the value has to be shifted by 2 bytes.
In Delphi with Direct Oracle Access we retrieve invalid values.
Using the PL/SQl-Developer we geht a .
Example:
create or replace type Level1 as object
"ID1" NUMBER
) NOT INSTANTIABLE NOT FINAL
CREATE OR REPLACE TYPE Level2 UNDER Level1
"ID2" NUMBER
NOT INSTANTIABLE NOT FINAL;
CREATE OR REPLACE TYPE Level3 UNDER Level2
REF3 REF LEVEl1
CREATE OR REPLACE TYPE Level4 UNDER Level3
"ID4" NUMBER
create or replace type Level5 UNDER Level4
date5 DATE
) INSTANTIABLE NOT FINAL;
CREATE TABLE level_table OF LEVEL1;
insert into level_table VALUES(LEVEL5(1,2,null,4, to_date('2010/10/23 09:10:11','yyyy/mm/dd hh24:mi:ss')));
select treat(value(trf) as LEVEL5),
treat(value(trf) as LEVEL5).date5 from level_table trf
Cheers,
Stephan
Example:
"ID1" NUMBER
"ID2" NUMBER
REF3 REF LEVEl1
"ID4" NUMBER
date5 DATE
Cheers,
Stephan
