problem with mailmerge ! PLEASE HELP ME!!
I am using the doa components together with the OfficePartner components (from turbopower) to create an address mailing.
The fields "house-number" contains number and sometimes letters (like "10a") I am using the TOracleDataSet component to create the dataset. [Select * from address]
the fieldtype is varchar(20).
The problem is, that all in all addresses, where the "house-no" is not numeric, that field is blanc.
It cannot be a problem with the Officepartner components, because with Interbase and the BDE they work fine.
Any ideas ?
Thanks for your help.
Thomas
I have difficulty believing that this could be a DOA problem.
As a quick test, create your OracleDataSet and attached a TDataSource and a TDBGrid.
This should immediately tell you if the problem is somewhere within DOA, Oracle or Net8. If this works then the problem is somewhere in your application logic...
hmmm,
of course, this works. But why do I not have any problems with Interbase ?
In my opinion, there must be a problem in recognizing the datatype of the result set.
In the meantime, I found out, that if rowcount is 1, then there is no problem. Onle if more than 1 records are given back to the app, this error occurs.
Any ideas ?
Thomas
