Problem with "Canvas can not draw..."
tomaten
i get this messege, when i import or export any large tables (394 tables and 5.000.000 records)! The im-/export crash after any hour and i can run all again :,-( ! This problem i see in v5.0.3 and have now also in 5.1 and the same problem! When i minimize the application then all run fine, i can not see, when is finished!
Maybe there is a memory leak in the import/export tools. We'll look into this.
Which method were you using: "Oracle Export", "SQL Inserts", or "PL/SQL Developer"?
