hbar
See below. I have auto-select query enabled, and I've had it working fine for years (except during beta for version 5...that was a painful time for me). However, every now and then something like what I have pictured below happens. See how the auto-select from the upper block grabs the "D" in DECLARE of the next block? It runs the first block fine, but nothing will correctly auto-select after that point, be they blocks or be they simple SQL. Once it decides to act up, the auto-select always misses the first character in the block or SQL from that spot in the window on down. The other blocks further up the page all still run fine. I can even copy a working one and paste it lower on the page and it will start acting funny.
The window in question actually has several blocks above what you can see on the screen, all of which run flawlessly using auto-select. Furthermore, all the code was taken directly from a working package (don't ask why) and pasted into this new window. It just doesn't make any sense.
Surely I'm not the only person to have seen this behavior?
