Problem when I modify data in OnGetData of the TOracleProvider
sparis
Do someone can try the DOA 3Tier demo with the following changes?
On the server:
- Add column 0 Test to the SELECT statement of DeptDataSet.
- In the OnGetData event of DeptProvider use this code:
DataSet.First;
  while not DataSet.EOF do
     Randomize;
     DataSet.Edit;
     DataSet.FieldByName('TEST').Value := Random(100);
     DataSet.Next;
[/i]
- Build the projet.
Connect you with the Client application and you will obtain 'Operation not applicabale' error. (It's what I have.)
If you replace all the DOA components by Delphi's original (TDataBase, TProvider and TQuery), no error occures.
BUG???
Excuse my english...
