Leigh Kendall
I'm having trouble opening projects using Visual SourceSafe. I can open the project OK, but when I try to check out files, there is only one folder in the check out window with no name; the subdirectories don't show.
If I use a root folder only for my scripts, works fine. But if the root folder has nothing in it, and all the scripts are in subdirectories, then I get the problem described in paragraph 1.
Is it only possible to use a single heirarchy project w/SourceSafe and PLSQL Developer? In the VCS help doc, there's a graphic that shows a MKS project with subdirectories that contain scripts.
Please help... Thanks,
Leigh Kendall
[This message has been edited by lkendall (edited 25 March 2003).]
Leigh Kendall
