I have installed Oracle client 10.2.0 on Vista business following the procedure on this blog:
http://cshay.blogspot.com/2007/02/getting-ready-for-windows-vista.html
You will need access to Metallink!
Additionally have installed PL/SQL developer ver. 7.0.3.1123 successfully, however the folloiwng registry entries were not defined, and had to import them manually into Vista in order to install the add-ins (BE extender, Active Query Builder, PlSQL doc).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer]
@="PL/SQL Developer file"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\DefaultIcon]
@="c:\\program files\\plsql developer\\plsqldev.exe,1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\Shell]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\Shell\Open]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\Shell\Open\Command]
@="\"c:\\program files\\plsql developer\\plsqldev.exe\""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\Shell\Open\ddeexec]
@="[Open(\"%1\")]"
Regards,
Jesmond
