Problem Report: hints in Program Window
ScottMattes
I just got
Error: Hint: Comparison with NULL in 'my_code'
Line: 2706
Text: IF something = ''
The compiler doesn't think that '' is the same as NULL (I tried changing the = to IS and recompiled - that threw a complier error), so why the hint?
SQL> select 1 from dual where '' is null;
         1
         1
The compiler most definitely thinks that '' is the same as NULL, because it is.
O, I thought that because of this:
SQL> select * from dual where dummy = '';
DUMMY
SQL> select * from dual where dummy is '';
ORA-00908: missing NULL keyword
SQL> select * from dual where dummy is null;
DUMMY
SQL>
that null and '' were different. Stewpid me.
p.s. yup, I was wrong -http://www.techonthenet.com/oracle/questions/empty_null.php
