Problem connecting through the internet
jpchausseau
I have an application using DOA which works fine on a LAN. However, I cannot connect to the database through a 'plain' internet connection as detailed below:
For development purposes, Oracle 8i is installed on a W2K workstation with IP adress 192.168.0.14. This workstation also runs Apache. No firewall on this workstation.
The LAN connects to internet through a router (nexLand) and a ADSL modem with a fixed IP adress. The router is configured to allow access to port 1521 (Oracle's listener) and port 80 (Apache) on workstation 192.168.0.14.
1- Now, if I try to connect to the database through the LAN, with the host name in Net8 defined as 192.168.0.14 (and port number 1521), everything works fine from another ('calling') workstation.
2- If I disconnect the 'calling' workstation from the LAN, and connect it to the internet through a modem and a phone line, I am unable to connect to the host name defined as above, but with the IP adress changed to the fixed ADSL modem adress ('ADSL_IP_adress'). However, I can connect to the Apache server on the workstation running the Oracle server, which should eliminate the router as the source of the problem.
3- If I connect the 'calling' workstation both to the LAN and to the internet with the modem and phone line, I can connect to Oracle by using either 192.168.0.14 or 'ADSL_IP_adress'.
Could this be a security problem on the workstation running Oracle? Any idea to help? Many thanks in advance,
Jean-Paul Chausseau
How is your listener configured? If it's listening by name, an internet connection probably won't work. If it's listening by IP address, it should.
It's listening by IP address (the IP address of the workstation running Oracle), i.e. 192.168.0.14.
Jean-Paul
