Hi all,
I'm trying to install a PL/SQL Developer version 14.0.6.1988 (64bit) on a Windows 10 Pro PC.
I've downloaded and unzipped Oracle Instant Client 21.3 Basic Package
Under the same directory I've create the network/admin/tnsnames.ora files and I've added the directory to the corresponding environment variables (Path the path where oci.dll is located "C:\instantclient_21_3" and TNS_ADMIN where .ora files are located "C:\instantclient_21_3\network\admin")
But PL/SQL Developer doesn't seems to detect the tnsnames.ora files as in PLSQL Developer Support Info -> Info -> DLLs and TNS File are empty. Tab TNS Names also empty
Really don't know what I can do.
Thanks in advance
Thanks in advance
