Hi Marco,
A minor flaw that you might like to assign to your local perfectionist.
I have configured Shift-Ctrl-P for 'SQL Window: Post Changes'.
When I edit a cell in the SQL Window result grid, and press this key, it causes a box-like character to be inserted into the cell that I have been editing rather than posting the changes to the database.
The edit-cursor has to be moved outside the SQL Window result grid to perform the Post Changes function using this key.
Workaround: Try another key. When F4 is configured for 'SQL Window: Post Changes' this behaviour is not observed.
[I shan't tell you how I remember that F4 is the key 4 the Post Changes function that I can't get using Shift-Ctrl-P.
Best Regards, Mark.
Best Regards, Mark.
