Plugin . SQL_SetPlugInSession
Buzz_ss
Hello.
How can I use function SQL_UsePlugInSession?
This function is described as :
function SQL_SetPlugInSession(PlugInID: Integer;
Username, Password, Database, ConnectAs:
PAnsiChar): Bool;
I tried next code:
function Change_SQL_PlugConnection():boolean ;
var
 curUserName, curPassword, curDatabase,curConnectAs :PAnsiChar;
  IDE_GetConnectionInfoEx(1,curUserName, curPassword, curDatabase,curConnectAs);
//  Result := SQL_UsePlugInSession(PlugInID) ;
  Result := SQL_SetPlugInSession(PlugInID, curUserName, curPassword,curDatabase, curConnectAs);
But It always return "False" and all SQL_functions continue using main connect. What is wrong?
Thank You.
Can you let me know your "Session Mode" preference and your "Allow multiple connections" preference? Both are located on the Oracle / Connection preferences page.
Session Mode must be "Multi Session" and "Allow multiple connections" must be enabled.
Thanks for Your reply.
Both preferences are correct.
Session Mode = "Multi Session"
and "Allow multiple connections" enabled
In debug I see that line :
return correct values for variables.
To obtain some more diagnostic information, can you modify the PL/SQL Developer shortcut and add the DebugSQL parameter? For example:
I have already found reason of my problem.
I had bug in my copy of unit PlugInIntf.
I had SQL_SetPlugInSession declaration as:
SQL_SetPlugInSession:function (PlugInID: Integer;Username, Password, Database, ConnectAs: PAnsiChar):Bool;
It was without "cdecl" directive. When I had written this directive the problem disappeared.
Sorry for Your time spent.
