Generating documentation for this package is corrupting the synopsis and the actual format.
Also spacing is not correct for tables made up with +-| (which looks pretty when using a non proportional font).
CREATE OR REPLACE PACKAGE test
Package spec text
IS
This is test comment
PROCEDURE test_1;
| Name | Value |
| Mon | 0 |
| Tue | 1 |
PROCEDURE test_2;
<code>
| Name | Value |
| Mon | 0 |
| Tue | 1 |
</code>
PROCEDURE test_3;
This is test comment which will span multiple lines and plsqldoc will
normally merge those lines together for the synopsis.
<code>
| Name | Value |
| Mon | 0 |
| Tue | 1 |
</code>
PROCEDURE test_4;
PROCEDURE test_5;
normally merge those lines together for the synopsis. This is test
comment which will span multiple lines and plsqldoc will normally merge
PROCEDURE test_6;
PROCEDURE test_7;
PROCEDURE test_8;
PROCEDURE test_9;
END;
