plsqldoc {*} problem
Jenean
My documentation look like this
Object for procedure parameters.
%author Jenean Spencer, 10/9/2007 4:50:37 PM
%attribute Procedure_Parameter_Id - Procedure parameter id.
%attribute Procedure_Id - Procedure id.
%attribute Position - Position of the parameter in the parameter list.
%attribute Parameter_Type - Parameter type.
{*}'IN'
{*} 'IN_OUT'
{*} 'OUT'
%attribute Parameter - Parameter name.
%attribute Data_Type - Data type.
%attribute Action - Defines what if any action should be associated with the
object.
{*} - 'INSERT'
{*} 'UPDATE'
{*} 'DELETE'
However when I generate my documentation the {*} bullet values are missing.
Type CIS_Procedure_Parameter_Obj
Author
Attributes
Action - Defines what if any action should be associated with the object.
What am I doing wrong?
Any help would be appreciated.
Valid values:
{*} IN
{*} IN_OUT
{*} OUT
object.
Valid values:
{*} INSERT
{*} UPDATE
{*} DELETE
The generated documentation looks like:
Author
Attributes
Parameter_Type - Parameter type Valid values:
IN
IN_OUT
OUT
Notice the {*} bullet values are displayed only if the they are not preceed by ".". Is this how they are supposed to work? Or is this a bug?
Thanks for you help.
