plsqldoc plugin won't load
jlcox
Downloaded and installed the new version twice, I get a error message when starting PLS:
"Could not activate Plug-In: PL/SQL Documentation (plsqldoc)"
I'm using v 6.0.5.926 of PLS.
Any ideas?
maybe, you have set registry entry in
HKEY_CURRENT_USER\Software\Allround Automations\PL/SQL Developer\PlugIns\plsqldoc from earlier installation for a directory pointing to another directory than new version expects it.
Change registry entry to new directory or delete it.
Hope it helps
Regards
Wilhelm Lamers
The error is indeed related to this directory change. We have fixed this, and the fixed version can be downloaded here .
