plsqldoc link to procedure in package body/definition
Hello!
Im using plsqldoc 1.2.0 with oracle 10g and pl/sql developer 8.0.4.
I need to set a {link} from the package body to the package definition. There are two files.
The p_utilities.imp:
CREATE OR REPLACE PACKAGE BODY p_utilities...
and the p_utilities.def:
CREATE OR REPLACE PACKAGE p_utilities...
In the def are the method headers and in the imp are the bodies of these methods. Only the method headers are documented to avoid a double and error-prone documentation. I would like to set a link from the imp part to the def part with:
{%link p_utilities.methodname}
This link jumps to the method body procedure instead of the documented header procedure.
Is there a way to differentiate between imp and def like:
{%link p_utilities.def.methodname}
{%link p_utilities.imp.methodname}?
with kind regards
Stephan Schielke
By the way:
Will there be a new version of plsqldoc?
Do you have documentation in both the package specification and body? I would expect you either use one or the other for documentation.
The documentation is only in the def.
But when iam developing im most of the time in the imp files.
I wanted a link to the def files.
Now {%link p_utilities.methodname} works.
I guess it was an usage problem.
The nested functions are documented but wont appear in the generated html. Are nested functions supported?
PROCEDURE name_of_method AS
/** text text text */
FUNCTION nested_function(...
END
