plsqldoc: Line prefix is not correctly handled when using %section
Niek
Generating documentation for this package specification is not correct - it will ignore all contents after a second line comment is found in combination with the
tags and custom plsqldoc tags...
Try it to see what I mean.
This section is wrong:
%History
<code>
#! 01/01/01  XX  NNNNNN   This is a test comment test with multiple lines
#!                        of text.
#!                        of text. This line should show up in the
#!                        documentation but it is not.
#! 01/01/01  XX  NNNNNN   This line should show up in the documentation but
#!                        it is not.
This line should show up also...
</code>
I included a full example with and without custom tags. Also I defined #! as a line prefix, so it doesn't show up in the documentation. We use special tags like --! / #! to identify code sections we are going to remove when shipping a next full release of our product.
Full spec:
CREATE OR REPLACE PACKAGE test
    This is test comment
<code>
-- 01/01/01  XX  NNNNNN   This is a test comment test with multiple lines
--                        of text.
--                        of text. This is a test comment test with
--                        multiple lines of text.
--                        of text.
</code>
<code>
#!                        of text.
#!                        of text. This is a test comment test with
#!                        multiple lines of text.
#!                        of text.
</code>
  %Usage
<code>
--                        of text.
--                        of text.
</code>
   %History
<code>
#!                        of text.
#!                        it is not.
</code>
IS
    test text
  PROCEDURE test_1;
END;
