plsqldoc cross-reference
I compiled the following code into the database:
create or replace package pkg1 is
-- proc_varchar2.
-- %obsolete
-- %see pkg2.proc_varchar2
procedure proc_varchar2;
-- proc_number.
-- %obsolete
-- %see pkg2.proc_number
procedure proc_number;
end pkg1;
create or replace package body pkg1 is
is
null;
is
null;
create or replace package pkg2 is
end pkg2;
create or replace package body pkg2 is
is
null;
is
null;
then I generated the documentation. The reference on the procedure proc_varchar2 to (%see) pkg2.proc_varchar2 does not generate a valid link. why ?
plsql developer 14.0.6.1911
plsqldoc 1.3.0.0
kind regards from austria
The issue seems to be related to the pkg2.proc_varchar2 name. As soon as I change the name to (for example) pkg2.proc_varchar2x the link is generated correctly.
We'll fix it.
