PL/SQL Warning: deprecated parameter PLSQL_DEBUG
Worker
When compiling a procedure with debug information (via "ALWAYS add debug info for connections") on an 11g database that has PLSQL_WARNINGS='ENABLE:ALL', I get the following warnings:
Error: PLW-06015: parameter PLSQL_DEBUG is deprecated; use PLSQL_OPTIMIZE_LEVEL = 1
Line: 1
Text: CREATE OR REPLACE PROCEDURE test_warnings AS
Error: PLW-06013: deprecated parameter PLSQL_DEBUG forces PLSQL_OPTIMIZE_LEVEL <= 1
Line: 1
Those warnings now no longer appear in the error pane (I think that's what it's called) of the program window. They also don't appear under the "Compile Invalid Objects" list.
They do still appear in the USER_ERRORS view when it is queried directly.
