Using 14.01.11965 64 bits.
Unable to replicate this anytime...
You do a simple select on a table.
You change the master connection or the window connection to another DB.
Execute the SQL (F8) then it freezes. You must kill the application.
You restart and reconnect on target DB and all is ok.
I have a couple of users experiencing this.
