PL/SQL Developer won't work on 64-bit machine
lezlee
Is there any plan to make PL/SQL Developer available in 64-bit?
We love PL/SQL Developer but we're getting new PCs at my place of employment and they are 64-bit machines. My co-workers with upgraded machines have had to abandon PL/SQL Dev. and are using Oracle SQL Developer.
If you're not planning on making a 64-bit version available, is there any kind of a work-around that would allow us to use PL/SQL Dev. from a 64-bit machine?
If you are planning on it (pretty please, do
), when will it be available?
PL/SQL Developer works fine on a 64 bit machine (that's how I use it). You will however need to install a 32 Bit Oracle11g or 12c Client. PL/SQL Developer is a 32 Bit application, so it cannot interface with a 64 Bit Oracle Client.
The 32 Bit Oracle Client can communicate with a 64 Bit Server, even on the same machine if necessary. The 32 Bit client can coexist with a 64 Bit Oracle installation when installed in separate Oracle Home directories.
The initial release of PL/SQL Developer 11.0 will be 32 Bit, but we'll have a 64 Bit version available in the first half of next year.
