Hi All,
This is my first post in this forum.
I am facing an issue in logging into PL/SQL developer as its showing no database connection strings in the drop down.
My question here is, if I install PL/SQL developer on my machine, then from Oracle home it directly takes the connection string from tnsnames.ora without mentioning explicitly.
Another thing is if I install PL/SQL developer on machine and trying to access via Citrix, then from where it will take the connection strings.
Thanks & Regards
Sanjay
Thanks & Regards
Sanjay
