I was trying to figure out why PL/SQL Developer takes forever to load. And I browsed thru the 'application data' directory and found a file in 'PFInfo' directory called 'files.info'. I see that it's 362kb. Looked thru the contents of it and looks like 'size' settings for the files we use for our source control.
1). Would the size of this file affect the loading of PLSDEV?
2). I would like to know how to disable writing this file settings so that the file doesn't bloat.
3). I see that the settings are of the files that we no longer use in our project anymore or moved over to different names AND locations. So, my question is if I can safely delete the file. Question 2's answer would help in figuring out future writing of this file.
4). Kind of related to this one, so, here it is. Where can I delete the 'projects' in the drop down in the setup of the VCS Plugin. I see that there are projects here that we no longer use. I tried to delete them from the actual Visual SourceSafe settings, but, they weren't mentioned there. Obviously these settings are local to the VCS plugin and I would like to delete the obsolete ones for us.
