Pl/Sql Developer startup is very slow
PL/SQL Developer
Version 9.0.0.1601
Windows XP Professional 5.1 Build 2600 (Service Pack 3)
Physical memory : 2.024.696 kB (1.100.904 available)
Paging file : 3.962.672 kB (3.079.328 available)
Virtual memory : 2.097.024 kB (2.015.164 available)
Parameters
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
25.8.2011 9:35:26 Application started
25.8.2011 9:35:26 InitPreferences
25.8.2011 9:35:26 Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
25.8.2011 9:35:26 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
25.8.2011 9:35:26 PreferenceSet.Load OK
25.8.2011 9:35:26 Determine LocalPrefPath
25.8.2011 9:35:26 [1]: C:\Program Files\PLSQL Developer\Preferences
25.8.2011 9:35:26 LocalPrefPath: C:\Program Files\PLSQL Developer\Preferences\zapata
25.8.2011 9:35:26 Load C:\Program Files\PLSQL Developer\Preferences\zapata = 0
25.8.2011 9:35:26 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\zapata\default.ini
25.8.2011 9:35:26 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\zapata\New.ini
25.8.2011 9:35:26 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\zapata\user.prefs
25.8.2011 9:35:26 InitPreferences end
25.8.2011 9:35:26 SortPreferenceSets
25.8.2011 9:35:26 - New
25.8.2011 9:35:26 - Default zapata
25.8.2011 9:35:26 - System Default
25.8.2011 9:35:26 DoUpdateChildList
25.8.2011 9:35:26 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
25.8.2011 9:35:26 ReadString OK
25.8.2011 9:35:26 pfReadRegistry: "C:\Program Files\PLSQL Developer\PLSQLDev.exe" "%1"
25.8.2011 9:35:26 LoadPreferences
25.8.2011 9:35:26 LoadPreferences searching for default
25.8.2011 9:35:26 C:\Program Files\PLSQL Developer\Preferences\zapata\default.ini
25.8.2011 9:35:26 C:\Program Files\PLSQL Developer\Preferences\zapata\New.ini
25.8.2011 9:35:26 LoadPreferences NewPref := nil
25.8.2011 9:35:26 LoadPreferences Reading preferences
25.8.2011 9:35:26 LoadPreferences ReadPosition
25.8.2011 9:35:26 LoadPreferences ToolsBrowserItemClick(nil)
25.8.2011 9:35:26 LoadPreferences CreateBrowserFilters...
25.8.2011 9:35:26 LoadPreferences Files
25.8.2011 9:35:26 LoadPreferences Buttons
25.8.2011 9:35:26 LoadPreferences Printer
25.8.2011 9:35:26 LoadPreferences FileBrowserFolders
25.8.2011 9:35:26 LoadPreferences Connections
25.8.2011 9:35:26 LoadPreferences BrowserFolders
25.8.2011 9:35:26 LoadPreferences end
25.8.2011 9:36:36 MacroLibFilename: c:\zapata.lib
25.8.2011 9:36:46 TOracleSession $02FE6740 Start Session.LogOn as scott@razvoj.WORLD
25.8.2011 9:36:54 TOracleQuery Query Start Query.Execute
25.8.2011 9:36:54 TOracleQuery Query End (1 record processed)
Duration = 0,062
25.8.2011 9:36:54 TOracleSession $02FE6740 End
Duration = 8,578
25.8.2011 9:36:54 TOracleQuery $02FA1190 Start Query.Execute
25.8.2011 9:36:54 TOracleQuery $02FA1190 End (1 record processed)
Duration = 0
25.8.2011 9:36:54 TOracleSession $02FE64A0 Start Session.LogOn as scott@razvoj.WORLD
Duration = 0
25.8.2011 9:36:54 TOracleSession $02FE64A0 End
Duration = 0,094
SQL = select * from v$version
25.8.2011 9:36:54 TOracleQuery BytesPerCharacterQuery Start Query.Execute
25.8.2011 9:36:54 TOracleQuery Query End (5 records processed)
Duration = 0
25.8.2011 9:36:54 TOracleQuery $02FA0ED0 Start Query.Execute
sys.plsqldev_authorization
25.8.2011 9:36:54 TOracleQuery $02FA0ED0 End
Duration = 0,015
25.8.2011 9:36:54 LogonHistorySave start
25.8.2011 9:36:54 ChangeUserPref LogonHistory,
25.8.2011 9:36:54 ChangeUserPref end
25.8.2011 9:36:54 ChangeUserPref DSA,
25.8.2011 9:36:54 ChangeUserPref ColumnAssociations,
25.8.2011 9:36:54 ChangeUserPref ImportAssociations,
25.8.2011 9:36:54 ChangeUserPref BrowserFilters,
25.8.2011 9:36:54 ChangeUserPref FileBrowserFolders,
25.8.2011 9:36:54 ChangeUserPref Connections,
25.8.2011 9:36:54 ChangeUserPref BrowserFolders,
25.8.2011 9:36:54 ChangeUserPref SessionQueries,
25.8.2011 9:36:54 ChangeUserPref ExternalTools,
25.8.2011 9:36:54 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0,031
25.8.2011 9:36:54 ChangeUserPref Documents,
25.8.2011 9:36:54 ChangeUserPref Reports,
25.8.2011 9:36:54 ChangeUserPref CurrentConnections,
25.8.2011 9:36:54 PreferenceSet.Save
25.8.2011 9:36:54 PreferenceSet Filename = C:\Program Files\PLSQL Developer\Preferences\zapata\user.prefs
25.8.2011 9:36:54 PreferenceSet AltFile = user.prefs
Duration = 0
25.8.2011 9:36:54 PreferenceSet.Save end
25.8.2011 9:36:54 TOracleQuery $02FA12F0 Start Query.Execute
SQL = /*
The name + type results of these queries will be used by the Code Assistant
if the "Describe Context" option is enabled. After typing 3 or more characters
the Code Assistant will show a list of matching names.
Separate multiple queries with semi-colons and use the :schema bind variable
to restrict names to the currently connected user.
In case of an error the query results will be omitted. No error message will
be displayed.
Place this file in the PL/SQL Developer installation directory for all users,
or in the "%APPDATA%\PLSQL Developer" directory for a specific user.
select object_name, object_type
from sys.all_objects o
where o.owner = :schema
:SCHEMA = SCOTT
25.8.2011 9:36:54 LogonHistorySave end
25.8.2011 9:36:54 FormCreate Logon.Executed -1
25.8.2011 9:36:54 FormCreate SessionChanged
Duration = 0
25.8.2011 9:36:54 TOracleQuery $02FA1030 Start Query.Execute
25.8.2011 9:36:54 TOracleQuery $02FA1030 End
Duration = 0,062
25.8.2011 9:36:54 SessionChanged SetDBAViews
25.8.2011 9:36:54 TOracleQuery $02FA1030 End (0 records processed)
Duration = 0,016
Duration = 0,031
Duration = 0
Duration = 0
SQL = select object_name from sys.dba_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
Duration = 0,016
SQL = select object_name from sys.all_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
25.8.2011 9:36:55 TOracleQuery $02FA12F0 End (4 records processed)
Duration = 0,437
25.8.2011 9:36:55 TOracleQuery $02FA12F0 Start Query.Execute
SQL =
select s.synonym_name as object_name, o.object_type
from all_synonyms s, sys.all_objects o
where s.owner in ('PUBLIC', :schema)
and o.owner = s.table_owner
:SCHEMA = SCOTT
25.8.2011 9:36:55 TOracleQuery $02FA1030 End (16 records processed)
Duration = 0,328
25.8.2011 9:36:55 SessionChanged Authorizations.Load
25.8.2011 9:36:55 SessionChanged EnableAuthorizedMenus
25.8.2011 9:36:55 ExecuteConnectScript starts
25.8.2011 9:36:55 TOracleQuery $02FA1030 Start Query.Execute
SQL = alter session set plsql_optimize_level = 2
Duration = 0
SQL = alter session set plsql_code_type = interpreted
Duration = 0
SQL = alter session set plscope_settings = 'identifiers:none'
Duration = 0
25.8.2011 9:36:55 ExecuteConnectScript ends
25.8.2011 9:36:55 SetSessionAction starts: Primary Session
SQL = select null from dual
25.8.2011 9:36:55 TOracleQuery $02FA1030 End (1 record processed)
Duration = 0
:ACTION = Primary Session
Duration = 0
25.8.2011 9:36:55 SetSessionAction ends
25.8.2011 9:36:55 SessionChanged LoadRecentObjects
25.8.2011 9:36:55 SessionChanged Logoff secondary sessions
25.08.2011 9:36:55 SessionChanged EnableChildFunctions
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient11g_home1
OracleHomeDir: D:\app\zapata\product\11.2.0\client_1
Found: oci.dll
Using: D:\app\zapata\product\11.2.0\client_1\bin\oci.dll
25.08.2011 9:36:55 Lock
25.08.2011 9:36:55 UnLock
25.08.2011 9:36:56 SortPreferenceSets
25.08.2011 9:36:56 - New
25.08.2011 9:36:56 - Default zapata
25.08.2011 9:36:56 - System Default
25.08.2011 9:36:56 TOracleQuery $02FA12F0 End (100 records processed)
Duration = 0,782
25.08.2011 9:36:56 TOracleQuery $02FA12F0 Start Query.Next for up to 100 records
Duration = 0,016
Duration = 0
Duration = 0
Duration = 0,032
25.08.2011 9:36:56 TOracleQuery $02FA1030 Start Query.Execute
25.08.2011 9:36:56 TOracleQuery $02FA1030 End (0 records processed)
Duration = 0,015
Duration = 0,031
Duration = 0,016
25.08.2011 9:36:56 Lock
25.08.2011 9:36:56 UnLock
Duration = 0,031
Duration = 0,031
Duration = 0,032
Duration = 0,046
Duration = 0,016
25.08.2011 9:36:56 DoUpdateChildList
Duration = 0,109
25.08.2011 9:36:56 FormActivate start
25.08.2011 9:36:56 FormActivate end
25.08.2011 9:36:56 WMUpdatePopups starts
25.08.2011 9:36:56 LoadDesktop starts
25.08.2011 9:36:56 LoadDesktop OpenProject
25.08.2011 9:36:56 OpenProject: C:\Program Files\PLSQL Developer\Projects\tecaj.prj
Duration = 0,094
25.08.2011 9:36:56 TOracleQuery Query Start Query.Execute
25.08.2011 9:36:56 TOracleQuery Query End (5 records processed)
Duration = 0,016
25.08.2011 9:36:56 SessionChanged SetDBAViews
Duration = 0
Duration = 0,016
25.08.2011 9:36:56 SessionChanged Authorizations.Load
25.08.2011 9:36:56 SessionChanged ApplyPreferences
25.08.2011 9:36:56 SessionChanged EnableAuthorizedMenus
25.08.2011 9:36:56 ExecuteConnectScript starts
Duration = 0
Duration = 0
Duration = 0,015
25.08.2011 9:36:56 ExecuteConnectScript ends
25.08.2011 9:36:56 SetSessionAction starts: Primary Session
25.08.2011 9:36:56 TOracleQuery $02FA1030 End (1 record processed)
Duration = 0
Duration = 0
25.08.2011 9:36:56 SetSessionAction ends
25.08.2011 9:36:56 SessionChanged LoadRecentObjects
25.08.2011 9:36:56 SessionChanged Logoff secondary sessions
25.08.2011 9:36:56 SessionChanged EnableChildFunctions
Found: oci.dll
25.08.2011 9:36:56 LoadDesktop ends
25.08.2011 9:36:56 WMUpdatePopups ends
25.08.2011 9:37:00 TOracleQuery $02FA12F0 End (100 records processed)
Duration = 3,406
25.08.2011 9:37:00 TOracleQuery $02FA12F0 Start Query.Next for up to 100 records
Duration = 0,282
Duration = 0,328
25.08.2011 9:37:01 TOracleQuery $02FA12F0 End (100 records processed)
Duration = 0,36
25.08.2011 9:37:01 TOracleQuery $02FA12F0 Start Query.Next for up to 100 records
Duration = 0,032
Duration = 0,093
Duration = 0,079
Duration = 0,046
25.08.2011 9:37:01 SortPreferenceSets
25.08.2011 9:37:01 - New
25.08.2011 9:37:01 - Default zapata
25.08.2011 9:37:01 - System Default
Duration = 0,141
Duration = 0,031
25.08.2011 9:37:01 TOracleQuery $02FA12F0 End (2 records processed)
Duration = 0,016
25.08.2011 9:37:01 TOracleQuery $02FA12F0 Start Query.Execute
SQL =
select db_link as object_name, 'DATABASE LINK' as object_type
from sys.all_db_links o
or o.owner = 'PUBLIC'
:SCHEMA = SCOTT
25.08.2011 9:37:01 TOracleQuery $02FA12F0 End (0 records processed)
Duration = 0,016
25.08.2011 9:37:01 TOracleSession $02FE64A0 Start Session.LogOff
25.08.2011 9:37:01 TOracleSession $02FE64A0 End
Duration = 0,015
25.08.2011 9:37:16 TStatistics.Init starts
25.08.2011 9:37:16 InitStatNames starts
25.08.2011 9:37:16 select name from v$statname order by statistic#
25.08.2011 9:37:16 TOracleQuery $02FA0ED0 Start Query.Execute
SQL = select name from v$statname order by statistic#
25.08.2011 9:37:16 TOracleQuery $02FA0ED0 End
Duration = 0,031
