Hi Marco, see the below:
PL/SQL Developer
Version 7.1.5.1397
Windows XP (64-bit) 5.1 Build 2600 (Service Pack 2)
Physical memory : 1,048,576 kB (1,048,576 available)
Paging file : 2,097,152 kB (1,048,576 available)
Virtual memory : 2,097,024 kB (1,960,324 available)
Parameters
C:\Program Files (x86)\PLSQL Developer\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
06/01/2012 14:56:10 Application started
06/01/2012 14:56:10 InitPreferences
06/01/2012 14:56:10 Load C:\Program Files (x86)\PLSQL Developer\Preferences\Default = 0
06/01/2012 14:56:10 PreferenceSet.Load C:\Program Files (x86)\PLSQL Developer\Preferences\Default\Default.ini
06/01/2012 14:56:10 PreferenceSet.Load OK
06/01/2012 14:56:10 Determine LocalPrefPath
06/01/2012 14:56:10 [1]: C:\Program Files (x86)\PLSQL Developer\Preferences
06/01/2012 14:56:10 LocalPrefPath: C:\Program Files (x86)\PLSQL Developer\Preferences\aking
06/01/2012 14:56:10 Load C:\Program Files (x86)\PLSQL Developer\Preferences\aking = 0
06/01/2012 14:56:10 PreferenceSet.Load C:\Program Files (x86)\PLSQL Developer\Preferences\aking\default.ini
06/01/2012 14:56:10 PreferenceSet.Load C:\Program Files (x86)\PLSQL Developer\Preferences\aking\user.prefs
06/01/2012 14:56:10 InitPreferences end
06/01/2012 14:56:11 SortPreferenceSets
06/01/2012 14:56:11 - Default aking
06/01/2012 14:56:11 - System Default
06/01/2012 14:56:11 pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
06/01/2012 14:56:11 ReadString OK
06/01/2012 14:56:11 pfReadRegistry: "C:\Program Files (x86)\PLSQL Developer\plsqldev.exe" "%1"
06/01/2012 14:56:11 LoadPreferences
06/01/2012 14:56:11 LoadPreferences searching for default
06/01/2012 14:56:11 C:\Program Files (x86)\PLSQL Developer\Preferences\aking\default.ini
06/01/2012 14:56:11 LoadPreferences NewPref := nil
06/01/2012 14:56:11 LoadPreferences Reading preferences
06/01/2012 14:56:11 LoadPreferences ReadPosition
06/01/2012 14:56:11 LoadPreferences ToolsBrowserItemClick(nil)
06/01/2012 14:56:11 LoadPreferences CreateBrowserFilters...
06/01/2012 14:56:11 LoadPreferences Files
06/01/2012 14:56:11 LoadPreferences Logon
06/01/2012 14:56:11 LoadPreferences Buttons
06/01/2012 14:56:11 LoadPreferences Printer
06/01/2012 14:56:11 LoadPreferences BrowserFolders
06/01/2012 14:56:11 LoadPreferences end
06/01/2012 14:56:11 MacroLibFilename: C:\Program Files (x86)\PLSQL Developer\Macro\aking.lib
06/01/2012 14:56:14 TOracleSession PLSQLDevForm.Session Start Session.LogOn as ipo_admin@PRODIPO
06/01/2012 14:57:17 TOracleSession PLSQLDevForm.Session End
Result = ORA-12547: TNS:lost contact
Duration = 63.25
06/01/2012 14:59:01 TOracleSession PLSQLDevForm.Session Start Session.LogOn as ipo_admin@PRODIPO
06/01/2012 14:59:01 TOracleQuery BytesPerCharacterQuery Start Query.Execute
06/01/2012 14:59:01 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.031
Duration = 0.063
06/01/2012 14:59:01 TOracleQuery Query Start Query.Execute
06/01/2012 14:59:01 TOracleQuery Query End (1 record processed)
Duration = 0.047
06/01/2012 14:59:01 TOracleSession PLSQLDevForm.Session End
Duration = 0.375
06/01/2012 14:59:01 LogonHistorySave start
06/01/2012 14:59:01 ChangeUserPref LogonHistory,
06/01/2012 14:59:01 ChangeUserPref DSA,
06/01/2012 14:59:01 ChangeUserPref end
06/01/2012 14:59:01 ChangeUserPref ColumnAssociations,
06/01/2012 14:59:01 ChangeUserPref ImportAssociations,
06/01/2012 14:59:01 ChangeUserPref BrowserFilters,
06/01/2012 14:59:01 ChangeUserPref BrowserFolders,
06/01/2012 14:59:01 ChangeUserPref SessionQueries,
06/01/2012 14:59:01 ChangeUserPref ExternalTools,
06/01/2012 14:59:01 ChangeUserPref Documents,
06/01/2012 14:59:01 ChangeUserPref Reports,
06/01/2012 14:59:01 LogonHistorySave end
06/01/2012 14:59:01 FormCreate Session.Connected
06/01/2012 14:59:01 FormCreate Logon.Executed -1
06/01/2012 14:59:01 FormCreate TDBNames.Make
06/01/2012 14:59:01 FormCreate SessionChanged
SQL = select * from v$version
06/01/2012 14:59:01 TOracleQuery Query End (5 records processed)
Duration = 0.031
06/01/2012 14:59:01 SessionChanged SetDBAViews
06/01/2012 14:59:01 TOracleQuery $0503C9F0 Start Query.Execute
06/01/2012 14:59:01 TOracleQuery $0503C9F0 End (0 records processed)
Duration = 0.047
Duration = 0.031
06/01/2012 14:59:01 SessionChanged Authorizations.Load
06/01/2012 14:59:01 TOracleQuery $0503C5D0 Start Query.Execute
sys.plsqldev_authorization
06/01/2012 14:59:01 TOracleQuery $0503C5D0 End
Duration = 0.047
06/01/2012 14:59:01 SessionChanged EnableAuthorizedMenus
06/01/2012 14:59:01 TOracleSession $057A0EA0 Start Session.LogOn as ipo_admin@PRODIPO
Duration = 0.047
06/01/2012 14:59:01 TOracleSession $057A0EA0 End
Duration = 0.266
06/01/2012 14:59:01 SetSessionAction starts: Main session
SQL = select null from dual
06/01/2012 14:59:01 TOracleQuery $0503C890 Start Query.Execute
from sys.user_objects o
06/01/2012 14:59:01 TOracleQuery $0503C9F0 End (1 record processed)
Duration = 0.047
:ACTION = Main session
Duration = 0.016
06/01/2012 14:59:01 SetSessionAction ends
06/01/2012 14:59:01 ExecuteConnectScript starts
06/01/2012 14:59:01 ExecuteConnectScript ends
06/01/2012 14:59:01 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
06/01/2012 14:59:01 TOracleQuery $0503C890 End (59 records processed)
Duration = 0.079
from all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
06/01/2012 14:59:01 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0.047
06/01/2012 14:59:01 SessionChanged LoadRecentObjects
06/01/2012 14:59:01 SessionChanged Notify children
06/01/2012 14:59:01 SessionChanged Logoff secondary sessions
06/01/2012 14:59:01 SessionChanged SessionMode = smMulti
06/01/2012 14:59:01 SessionChanged EnableChildFunctions
06/01/2012 14:59:02 SessionChanged
OCIDLL forced to C:\app\aking\product\11.2.0\client_1\bin\oci.dll
06/01/2012 14:59:02 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
06/01/2012 14:59:02 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0.031
06/01/2012 14:59:02 TOracleQuery $0503C890 End (100 records processed)
Duration = 0.296
06/01/2012 14:59:02 TOracleQuery $0503C890 Start Query.Next for up to 100 records
Duration = 0.016
Duration = 0.031
Duration = 0.016
Duration = 0.031
Duration = 0.016
06/01/2012 14:59:02 SortPreferenceSets
06/01/2012 14:59:02 - Default aking
06/01/2012 14:59:02 - System Default
Duration = 0.031
Duration = 0.015
Duration = 0.032
06/01/2012 14:59:02 TOracleQuery $0503C730 Start Query.Execute
Duration = 0.015
06/01/2012 14:59:02 TOracleQuery $0503C730 End (0 records processed)
Duration = 0.046
Duration = 0.031
Duration = 0.016
Duration = 0.032
Duration = 0.031
Duration = 0.016
Duration = 0.016
Duration = 0.016
Duration = 0.016
Duration = 0.031
Duration = 0.032
06/01/2012 14:59:02 WMUpdatePopups starts
06/01/2012 14:59:02 GetCrashList: 1049914.cfg
Duration = 0.015
Duration = 0.031
Duration = 0.016
Duration = 0.047
Duration = 0.031
Duration = 0.031
Duration = 0.032
Duration = 0.031
Duration = 0.031
06/01/2012 14:59:03 TOracleQuery $0503C890 End (100 records processed)
Duration = 0.047
06/01/2012 14:59:03 TOracleQuery $0503C890 Start Query.Next for up to 100 records
Duration = 0.031
Duration = 0.016
Duration = 0.047
Duration = 0.047
06/01/2012 14:59:04 Create TSQLForm Start
06/01/2012 14:59:04 Create TSQLForm Inherited
06/01/2012 14:59:04 TSQLForm.FormCreate Start
06/01/2012 14:59:04 SQLForm
06/01/2012 14:59:04 TSQLForm.FormCreate Finished
06/01/2012 14:59:04 Create TSQLForm SetupMainFont
06/01/2012 14:59:04 Create TSQLForm Activate
06/01/2012 14:59:04 Create TSQLForm Activate done
06/01/2012 14:59:04 Create TSQLForm UpdateWindowList
06/01/2012 14:59:04 Create TSQLForm Positioning
06/01/2012 14:59:04 Create TSQLForm Finished
06/01/2012 14:59:04 FileAge: C:\Users\aking\AppData\Local\Temp\2\PLS-Recovery\1049914.001 = 14:51:10
06/01/2012 14:59:04 SQLForm Recovery file loaded
06/01/2012 14:59:04 TOracleQuery $0503C890 End (100 records processed)
Duration = 1.453
06/01/2012 14:59:04 TOracleQuery $0503C890 Start Query.Next for up to 100 records
06/01/2012 14:59:04 AddNavigationBookmark starts
Duration = 0.141
06/01/2012 14:59:04 FileAge: C:\Users\aking\AppData\Local\Temp\2\PLS-Recovery\1049914.002 = 14:51:10
Duration = 0.063
06/01/2012 14:59:04 NavigationBookmarks.EnableButtons(Rebuild)
06/01/2012 14:59:04 NavigationBookmarks: Backward=0, Forward=0
06/01/2012 14:59:04 WMUpdatePopups ends
06/01/2012 14:59:05 TOracleQuery $0503C890 End (100 records processed)
Duration = 0.281
06/01/2012 14:59:05 TOracleQuery $0503C890 Start Query.Next for up to 100 records
Duration = 0.032
Duration = 0.015
Duration = 0.078
Duration = 0.047
Duration = 0.016
Duration = 0.031
Duration = 0.047
Duration = 0.032
Duration = 0.015
Duration = 0.031
Duration = 0.047
Duration = 0.032
Duration = 0.015
Duration = 0.031
Duration = 0.016
Duration = 0.031
Duration = 0.016
Duration = 0.016
Duration = 0.031
Duration = 0.015
Duration = 0.032
Duration = 0.015
Duration = 0.032
Duration = 0.015
Duration = 0.016
Duration = 0.031
Duration = 0.047
Duration = 0.031
06/01/2012 14:59:05 TOracleQuery $0503C890 End (4 records processed)
Duration = 0.031
06/01/2012 14:59:05 TOracleSession $057A0EA0 Start Session.LogOff
06/01/2012 14:59:06 TOracleSession $057A0EA0 End
Duration = 0.032
06/01/2012 14:59:09 Create TSQLForm Start
06/01/2012 14:59:09 Create TSQLForm Inherited
06/01/2012 14:59:09 TSQLForm.FormCreate Start
06/01/2012 14:59:09 SQLForm
06/01/2012 14:59:09 TSQLForm.FormCreate Finished
06/01/2012 14:59:10 AddNavigationBookmark starts
06/01/2012 14:59:10 AddNavigationBookmark GNV00001
06/01/2012 14:59:10 NavigationBookmarks.EnableButtons(Rebuild)
06/01/2012 14:59:10 NavigationBookmarks: Backward=1, Forward=0
06/01/2012 14:59:10 AddNavigationBookmark ends
06/01/2012 14:59:10 Create TSQLForm SetupMainFont
06/01/2012 14:59:10 Create TSQLForm Activate
06/01/2012 14:59:10 Create TSQLForm Activate done
06/01/2012 14:59:10 Create TSQLForm UpdateWindowList
06/01/2012 14:59:10 Create TSQLForm Positioning
06/01/2012 14:59:10 Create TSQLForm Finished
06/01/2012 14:59:20 SQLForm Initializing...
06/01/2012 14:59:20 SetConnected starts
06/01/2012 14:59:20 SetConnected: Connect starts
06/01/2012 14:59:20 TOracleSession $057AB6A0 Start Session.LogOn as ipo_admin@PRODIPO
06/01/2012 14:59:20 TOracleQuery Query Start Query.Execute
06/01/2012 14:59:20 TOracleQuery Query End (1 record processed)
Duration = 0.031
06/01/2012 14:59:20 TOracleSession $057AB6A0 End
Duration = 0.266
06/01/2012 14:59:20 SetConnected: (Dis)connect ends
06/01/2012 14:59:20 SetSessionAction starts: SQL Window - New
06/01/2012 14:59:20 TOracleQuery $0503C050 Start Query.Execute
06/01/2012 14:59:20 TOracleQuery $0503C050 End (1 record processed)
Duration = 0.047
06/01/2012 14:59:20 TOracleQuery BytesPerCharacterQuery Start Query.Execute
06/01/2012 14:59:20 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.031
Duration = 0.047
:ACTION = SQL Window - New
Duration = 0.016
06/01/2012 14:59:20 SetSessionAction ends
06/01/2012 14:59:20 ExecuteConnectScript starts
06/01/2012 14:59:20 ExecuteConnectScript ends
Duration = 0.046
06/01/2012 14:59:20 EnableOutput starts
06/01/2012 14:59:20 TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable
size);
end if;
:ENABLE = 1
:SIZE = 10000
06/01/2012 14:59:20 TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0.016
06/01/2012 14:59:20 EnableOutput done
06/01/2012 14:59:20 InitStatistics starts
06/01/2012 14:59:20 TStatistics.Init starts
06/01/2012 14:59:20 InitStatNames starts
06/01/2012 14:59:20 select name from v$statname order by statistic#
06/01/2012 14:59:20 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select name from v$statname order by statistic#
06/01/2012 14:59:20 TOracleQuery PLSQLDevForm.DynamicQuery End (25 records processed)
Duration = 0.047
06/01/2012 14:59:20 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Next for up to 25 records
Duration = 0.016
Duration = 0.015
Duration = 0.031
Duration = 0.016
Duration = 0.016
Duration = 0.015
Duration = 0.032
Duration = 0.015
Duration = 0.031
Duration = 0.016
Duration = 0.031
Duration = 0.016
Duration = 0.016
Duration = 0.031
Duration = 0.015
Duration = 0.032
Duration = 0.015
Duration = 0.016
Duration = 0.015
Duration = 0.016
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.DynamicQuery End (25 records processed)
Duration = 0.031
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Next for up to 25 records
Duration = 0.031
Duration = 0.032
Duration = 0.031
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.DynamicQuery End (13 records processed)
Duration = 0.031
06/01/2012 14:59:21 InitStatNames ends
06/01/2012 14:59:21 StatQuery.Describe starts
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.StatQuery Start Query.Describe
SQL = select value from v$sesstat where sid = :sid order by statistic#
:SID = Null
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.StatQuery End
Duration = 0.031
06/01/2012 14:59:21 StatQuery.Describe ends
06/01/2012 14:59:21 TStatistics.Init ends
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.StatQuery Start Query.Execute
:SID = 145
06/01/2012 14:59:21 TOracleQuery PLSQLDevForm.StatQuery End (638 records processed)
Duration = 0.063
06/01/2012 14:59:21 InitStatistics ends
06/01/2012 14:59:21 NavigationBookmarks.EnableButtons(Rebuild)
06/01/2012 14:59:21 NavigationBookmarks: Backward=1, Forward=0
06/01/2012 14:59:21 SQLForm Executing...
06/01/2012 14:59:21 TSQLThread SQLThread.Execute
06/01/2012 14:59:21 TOracleQuery Query Start Query.Execute
:ID = Null
06/01/2012 14:59:21 TOracleQuery Query End
Duration = 0.016
06/01/2012 14:59:21 TOracleQuery $0503B970 Start Query.Execute
SQL = select * from d_item
06/01/2012 14:59:36 Aborting thread
06/01/2012 14:59:38 Aborting thread
06/01/2012 14:59:40 Aborting thread
06/01/2012 14:59:42 Aborting thread
06/01/2012 14:59:43 Aborting thread
06/01/2012 14:59:45 Aborting thread
06/01/2012 14:59:47 Aborting thread
06/01/2012 14:59:49 Aborting thread
06/01/2012 14:59:51 Aborting thread
06/01/2012 14:59:53 Aborting thread
06/01/2012 14:59:54 Aborting thread
06/01/2012 14:59:56 Aborting thread
06/01/2012 14:59:58 Aborting thread
06/01/2012 14:59:59 Destroying TSQLForm
06/01/2012 15:00:21 TOracleSession $057AB6A0 Start Session.LogOff
06/01/2012 15:00:21 TOracleSession $057AB6A0 End
Duration = 0
06/01/2012 15:00:21 TOracleQuery $0503B970 End
Result = ORA-03113: end-of-file on communication channel
Process ID: 24126
Session ID: 145 Serial number: 34011
Duration = 59.703
06/01/2012 15:00:21 TSQLThread SQLThread Postmessage
06/01/2012 15:00:21 TSQLThread SQLThread Suspend
06/01/2012 15:00:21 TSQLThread SQLThread Suspend ended
06/01/2012 15:00:21 Destroyed TSQLForm
06/01/2012 15:00:23 TSQLForm.ThreadFinished
06/01/2012 15:00:23 Exception: Access violation at address 00929FDA in module 'plsqldev.exe'. Read of address 0000000E
06/01/2012 15:00:23 Exception: A call to an OS function failed
06/01/2012 15:00:23 AddNavigationBookmark starts
06/01/2012 15:00:23 AddNavigationBookmark GNV00002
06/01/2012 15:00:23 NavigationBookmarks.EnableButtons(Rebuild)
06/01/2012 15:00:23 NavigationBookmarks: Backward=1, Forward=0
06/01/2012 15:00:23 AddNavigationBookmark ends
06/01/2012 15:00:30 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:30 TOracleQuery Query End (5 records processed)
Duration = 0.031
06/01/2012 15:00:30 TOracleQuery $0503BD90 Start Query.Execute
SQL = select * from nls_database_parameters where parameter like 'NLS%CHARACTERSET'
06/01/2012 15:00:30 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.047
06/01/2012 15:00:35 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:35 TOracleQuery Query End (5 records processed)
Duration = 0.062
06/01/2012 15:00:35 TOracleQuery $0503BD90 Start Query.Execute
06/01/2012 15:00:35 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.063
06/01/2012 15:00:40 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:40 TOracleQuery Query End (5 records processed)
Duration = 0.14
06/01/2012 15:00:40 TOracleQuery $0503BD90 Start Query.Execute
06/01/2012 15:00:40 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.125
06/01/2012 15:00:44 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:44 TOracleQuery Query End (5 records processed)
Duration = 0.047
06/01/2012 15:00:44 TOracleQuery $0503BD90 Start Query.Execute
06/01/2012 15:00:44 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.031
06/01/2012 15:00:49 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:49 TOracleQuery Query End (5 records processed)
Duration = 0.047
06/01/2012 15:00:49 TOracleQuery $0503BD90 Start Query.Execute
06/01/2012 15:00:49 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.031
06/01/2012 15:00:54 TOracleQuery Query Start Query.Execute
06/01/2012 15:00:55 TOracleQuery Query End (5 records processed)
Duration = 0.063
06/01/2012 15:00:55 TOracleQuery $0503BD90 Start Query.Execute
06/01/2012 15:00:55 TOracleQuery $0503BD90 End (2 records processed)
Duration = 0.062
