PL/SQL developer not found. Please install first [SOLVED?]
Tim Scott
Help,
I really like the TortoiseSVN plugin (plsqldev-svn-plugin-setup_0.0.19.0.exe), but it won't install because it can't find my PL/SQL Developer installation.
Neither could FindAll or highlighting, but I could install those manually .. this one takes a bit more fiddling.
I know I've installed the 32-bit plsqldev1106 because it says plsqldev.exe *32 in Task Manager.
Is there something I can do to get this working, or do I have to wait for PL/SQL Developer to be properly licensed and no longer "on trial"?
Tim
I had some other Windows issue - not sure what caused that, but ...
Anyway I had cause to try to launch PL/SQL Developer from the Start menu, but it wasn't there !
I manually created a Shortcut in:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PLSQL Developer
by copying / Paste Shortcut to the desktop and then moving it to this folder. I had to paste it to the desktop first, because Pasting shortcuts can't prompt for admin rights, but moving a file can.
There was an issue automatically adding the toolbar icons, but that's the least of my worries right now ...
