PL/SQl Developer is very slow
jlt
PL/SQL Developer version: 7.0.3.1123
PL/SQl Developer is very slow to start.
Debug.txt:
08/10/2007 10:09:41 TOracleSession $021AAEB0 Start Session.LogOn as dba@Vendeur
08/10/2007 10:10:05 TOracleQuery Query Start Query.Execute
08/10/2007 10:10:05 TOracleQuery Query End (1 record processed)
Duration = 0
08/10/2007 10:10:05 TOracleSession $021AAEB0 End
Duration = 23,078
Any idea?
Thanks.
JLT.
This may be an Oracle Net configuration issue. Can you send me the sqlnet.ora file from your \Network\Admin directory?
File's content:
# C:\ORANT\NET80\ADMIN\SQLNET.ORA Configuration File:C:\orant\net80\admin\sqlnet.ora
# Generated by Oracle Net8 Assistant
NAME.DEFAULT_ZONE = world
NAMES.DEFAULT_DOMAIN = world
NAMES.PREFERRED_SERVERS =
(ADDRESS_LIST =
(ADDRESS=(PROTOCOL=TCP)(HOST=182.219.269.15)(PORT=1575))
sqlnet.authentication_services = (NONE)
names.directory_path = (ONAMES, TNSNAMES)
#names.directory_path = (TNSNAMES, HOSTNAME)
SQLNET.EXPIRE_TIME = 0
#SQLNET.ENCRYPTION_SERVER = requested
#SQLNET.ENCRYPTION_CLIENT = requested
Looks okay. To obtain some more diagnostic information, can you modify the shortcut and add the debugsql parameter? For example:
