PL/SQL Developer Delays/Fails to Start
adam133
Hello, just wondering if anyone else has the same issue I have. Seems that PL/SQL developer will refuse to start if I am connected to VPN. Using Cisco Anyconnect client. If I disconnect from the VPN, PL/SQL developer starts immediately. I am on Windows 7, running 32 bit PL/SQL developer on a 64 bit machine.
