pl/sql developer 5.x not working with 9i
We are running 5.0.1.480 and are not able to retrieve data from tables on Oracle 9I databases.
8I works just fine.
The error message we get for 9I is "table/view doesn't exists" when running a select statement. However, we do see the tables on the left navigation window.
We installed 9i client but this was not the answer. bruce.sanders@mail.sprint.com
I suspect a problem with the Automatic Statistics feature.
To use the Automatic Statistics feature you need select privileges for the he v$session, v$sesstat and v$statname views. I think one or two privileges are missing.
The SYS user owns these views, so only the SYS user can grant privileges on them. Oracle has defined a standard "plustrace" role that contains exactly these privileges. You can find the script to create this role in %oracle_home%/sqlplus/admin/plustrce.sql. Just start SQL*Plus, connect as SYS, and execute this script. If you do not have this script, here are its contents:
create role plustrace;
grant select on v_$sesstat to plustrace;
grant select on v_$statname to plustrace;
grant select on v_$session to plustrace;
grant plustrace to dba with admin option;
Now that you have created the plustrace role, make sure that it is granted to the PL/SQL Developer user(s), and you're done.
V_$session is no longer granted to plustrace since RDMBS 9.2.0.3 AFAIK. It is not needed for tracing: v$mystat is sufficient. But (unpached) PSD 7.0.3.1123 refuses to use Automatic Statistics when it can't execute "select sid, serial# from v$session where audsid = userenv('SESSIONID')". Is that fixed in later versions?
