We have released Beta 6 32 bit and Beta 6 64 bit with the following fixes and enhancements:
- PLW-07207 added to the compiler preferences warning list
- Internal Query Builder images were not clear in dark mode
- Workset Logon would ask for password when it was known from the Connection Definition
- Hyperlink indicator for a marked identifier could be an unreadable color combination
- PL/SQL Beautifier did format multi-line q'strings correctly when not using brackets and the 2nd character is a quote (e.g. q'*'...LF...'*')
- Command Window CONNECT command could close the Object Browser items, even in another instance of PL/SQL Developer
- Worksets and Crash recovery now only store the password when "Store with password" preference is set
- Project files will now follow the main connection if not pinned
- Improved commit and rollback icon colors when enabled
- Key Configuration was not always stored
- SQL Window Single Record View horizontal scrollbar did not behave correctly
- Diagram Window Line Labels setting is now stored with default line settings
- Diagram Window automatically added related table would not always show
- Command Window BEAUTIFY command for package and type database objects now processes both the specification and body
- Fixed Program Window Editor flashing during compilation
- Some checkbox captions were truncated
- SQL Window DBMS Output tab page now indicates when output has been written
- SQL Window Export Query Results would fail after clearing previous results
