We have released Beta 5 32 bit and Beta 5 64 bit with the following fixes and enhancements:
- Help > Check Online Updates selected line colors could be incorrect
- Command Window status line error messages could be vertically misaligned
- Mouse wheel scrolling in a grid did not update the scrollbar
- Window List indicator colors improved for the selected window
- Logon History list in the preferences made wider
- Preference added: Use default Alt shortcuts for Ribbon
- Comment Line function (Ctrl -) now also works for multiple selected lines
- Selecting text from the Command Window error text would navigate to the Editor tab page
- Improved icon colors for the Object Browser and Connection List
- Using a function key for the "Object: Rename" function did not always focus on the name field
- Preference Search list color could be incorrect
- Starting PL/SQL Developer with a Workset now suppresses the initial logon dialog
- Program Window Code Contents buttons did not have enough space
- Export User Objects did not conform to the file encoding preferences (ANSI/UTF8/BOM)
- Ribbon Display Options button removed
- Key configuration did not always work correctly
