We have released Beta 2 32 bit and Beta 2 64 bit with the following fixes and enhancements:
- Window List connection indicator color was not always correct
- Title bar color of some forms (Statement Recall, Text Editor) could be incorrect
- In Dark Mode some blue colors were too dark
- Object Browser connection indicator did not work
- 64 bit version did not have correct main icon
- Workset Manager could give error when no Worksets are available
- File -> Properties dialog would cause visual and stability problems
- Updated image in the Logon dialog
- Logon Dialog after Ctrl-H could suppress the first typed character of the password
- Oracle Scheduler Job Run Details and Job Logs popup menu now includes a "Fetch All" item
- Object Browser performance was not optimal when reopening folders
- Added example images to "reduce icon size" preference
- Starting the 64 bit version on Windows 10 1607 or earlier could lead to an "OpenThemeDataForDpi could not be found" error
- Project Item names could be wrapped
- Date/Time picker was not displayed correctly in dark mode
- The Application Title could include the current filename twice
- Newly created windows would not always be on top
- Date/Time picker default date is now today
- Break and Kill icons are now red
- Buttons for Close and Restore added when Single Document Interface preference "Don't show tabs" is enabled.
- New Code Contents icons for parameters and record fields to prevent ambiguity
