PL/SQL Developer 12 default screen layout while using remote desktop connection
Vladislav
I'm using PL/SQL developer 12.0.3.1821 on Windows 7 Professional
I've changed PL/SQL developer layout and saved it.
While working with PL/SQL Developer locally everything works fine.
When I connect to my Workstation using remote desktop connection, PL/SQL developer uses default screen layout.
Can you go to Preferences > User Interface / Options and check if the "Save layout per multi monitor setup" option is enabled? If it is enabled, can you disable it and try again?
