PL/SQL Dev 6 and Oracle 10g - Problems
t21931
Hi everyone,
My company is using PL/SQL Developer 6.0.5 with Oracle Client 9i installed (for SQLNET client).
We've started connecting to an Oralce 10G database and some developers have experienced problems.
Specifically, PL/SQL Developer just quits/shuts down for no apparent reason.
Has anyone seen this before? Should we install Oracle 10G SQLNET Client?
THANKS!
- Pedro
The Oracle 10G database that we connect to is:
Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bit Production
With the Partitioning, OLAP and Data Mining options
Thanks - how do I get either the patch or the updgrade? I only see PL/SQL Dev 7 in the download section.
We are seeing something very similar - however we are already using Version 7.0.0.1050 (MBCS)7.
The problem occurs when querying tables with clobs
some rows load but others return in the clob column. after a few such rows connection with database is lost.
We've seen this too - I thought it was related to the version we're using.
Maybe there's something larger going on.
This seems like a different problem to me. Version 7.0 should not have any problem with Oracle 10.2.
i have the same issue with expanding the tables' tree. plsql developer version 7.0.2.1076, Oracle 10.2g
I have a similiar performance problem when viewing or editing a user. After selecting a user it takes more than a minute till the data of the user appears. I will send the debug and version information to support@allroundautomation.com
Kind regards,
Peter
