PL/SQL and Greek
iraklisvai
I have installed pl/sql developer v 12.0.7.1837 on my pc. All are ok.
When I installed it, on a Windows 2008 Server Remote Desktop Connection, with the same preferences, it does not understand Greek. I mean, when i make a select * from tableA, if tableA has colums with Greek names, it displays ???? instead of the name.
When I connect to this database from my pc, and I make the same select statement, all are ok.
I have looked at Preferences, Fonts, Main Font, Script is Greek.
I have also looked at regional settings, all are Greek.
I have also look at regedit, NLS_LANG parameter is AMERICAN_AMERICA.EL8ISO8859P7
Finally, both pl/sql Developers have the same client.
What is wrong?
Thank you very much.
Hello Irakli,
What is the setting at
Language Settings -> Administrative Language Settings -> Language for Non-Unicode Programs ? It should be Greek too (I think)
Aris
Maybe this is an environment problem. Can you start PL/SQL Developer, connect to this database, go to Help > Support Info and send me the text from the "Info" tab page?
PL/SQL Developer
Version 12.0.7.1837 (64 bit)
01.276182 - Unlimited user license
Service Contract:
Windows 7 Build 7601 (Service Pack 1)
Physical memory : 25.165.368 kB (6.708.528 available)
Paging file : 50.328.876 kB (28.095.464 available)
Virtual memory : 8.589.934.464 kB (8.589.567.072 available)
Parameters
C:\Program Files\PLSQL Developer 12\plsqldev.exe
InstantClient=C:\Oracle\instantclient_10_2
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer 12\Preferences\Default\Default.ini
C:\Users\IR\AppData\Roaming\PLSQL Developer 12\Preferences\Vaindirlis\default.ini
License File
C:\ProgramData\PLSQL Developer\aalf.dat
Debug file
C:\Program Files\PLSQL Developer 12\PlSqlDev.elf
Plug-Ins
*Active Query Builder (C:\Program Files\PLSQL Developer 12\PlugIns\ActiveQueryBuilder.dll)
*PL/SQL Documentation (plsqldoc) (C:\Program Files\PLSQL Developer 12\PlugIns\plsqldoc.dll)
(* is Active)
Aliases
APD
APD.IKA4
Beq-local.world
bidb
bidb_contr_ops
Homes
DLLs
c:\oracle\instantclient_10_2\oci.dll
TNS File
C:\Oracle\instantclient_10_2\tnsnames.ora
Using
Home:
DLL: C:\Oracle\instantclient_10_2\oci.dll
OCI: Version 10.2 (10.2.0.5.0)
Oracle Database 10g Enterprise Edition Release 10.2.0.5.0
Character Sets
Character size: 1 byte(s)
CharSetID: 37
NCharSetID: 2000
Unicode Support: True
NLS_LANG:
NLS_CHARACTERSET: EL8ISO8859P7
Process
Working Set = 138.014.720
Memory = 46.992.032
GDI Objects = 741
User Objects = 382
Handles = 208
Monitor
PixelsPerInch = 96
Id = 0
Primary = True
Handle = 65537
Left = 0
Top = 0
Width = 1680
Height = 1050
MainFormOnTaskbar = False
I think i found the reason. But why?
In Remote PC
NLS_LANG:
In my PC
NLS_LANG: AMERICAN_AMERICA.EL8ISO8859P7
That is indeed the reason. For the Oracle Instant Client you need to set the NLS_LANG environment variable on the PC.
NLS_LANG is the variable that Oracle client checks in order to perform (any) translation between server and client.
For MS Windows clients you need EL8MSWIN1253, for UX usually EL8ISO8859P7 will do.
