PL SQL 12 Compile Invalid Objects does not allow filter by mask
Niki
PL SQL 12 Compile Invalid Objects makes filter only by USER and does not filter objects by Objects filter, as it was in PL SQL 11.
It should be better to add field to Compile Invalid Objects to filter big list of objects, or make it as in PL SQL 11.
Implicitly using the Object Browser caused a lot of confusion. Maybe we can re-add it as an explicit option.
This is a huge step back in functionality. I used the Objects filter to compile everyday.
How do I get the 'Compile Invalid Objects' to default to a different user than ''. I could not find how to change this in the Help file.
You can go to Configure > Preferences > User Interface / Options and deselect the "Preselect current user for object selection lists" option.
It looks like I can turn off the current user but cannot set the default to a different user. Is this correct?
Additionaly I'll say about one old trouble. The compilation in "Compile invalid objects" window locks entire application still. It's very sad
