PB with factoring subquery
r2363c
this query work in SQL*plus
with C as (select * from emp)
select * from C
but not in PL/sql dev
but this one (very similar) yes
select * from (
select * from C
I think it's a bug on factoring subquery handling.
I've just downloaded the last realease of pl/sql dev.
Do you have the same behavior ?
because I fear it was a NET8 issue ?
However in metalink someone got the same issue with TOAD.
Laurent
Works fine for me on Oracle9i 9.0. What is your client/server version? What is the error message?
I've just tested on 9i, that's work too.
But on 8.0.5 client, it doesnt work.
on 8.1.6 it doesn't work too.
no error message, just no row !!!
But on sql*plus 8.1.6 it give
SP2-0642: SQL*Plus internal error state 2091, context 0:0:0
Unsafe to proceed
it's really stange !!!
I think that Oracle Net 8.x and earlier do not recognize this as a select statement.
