PasteOptions problem
ScottMattes
This is weird. I have PO on the PC where I do my email and it works just fine, but when I copy the .dll and .ini and carry to where I do my work the options do not appear on the Edit menu.
I can see PO loading when PLSD starts. I can even go to Tools / Configure Plugins and see that PO is there and the checkbox is checked.
The .ini is exactly like that on the working PC. I have even gone so far as to download from the web and install from the zip.
And PLSD wasn't running when I did the install.
Scott,
I noticed the same too. It worked for me, when I opened the ini-file in a text editor, where I let all the tabs be displayed and reentered the text (and made sure that tabs were not replaced by blanks).
For me it looks that the plugin has problems with correct identification of the tabs.
greetings,
Uli
I'll try that when I get some time. It seems real strange that the .ini from the zip file (with no mods, didn't even open it to look in it) failed to work on the second PC.
I've figured out, that PO use .dll from directory configured in "Preferences|Directories|Plug-Ins" even when this is not the default (e.g. ...plsqldev\PlugIns).
On the other hand, .ini will only be used from the default directory even when there is a different directory configured.
I've found this effect some month ago, so I hope my statement is still accurate.
frank
