I am using Oracle 9i with Delphi 6.0
here is the package code
Create or replace package Contact_Actions AS
Type t_ContactCursor is ref cursor return contact%rowtype;
Procedure GetAllContacts ( p_ContactCursor in out t_Contactcursor );
End Contact_Actions;
Create or replace package body Contact_Actions AS
Procedure Getallcontacts ( p_ContactCursor in out t_Contactcursor ) is
open p_ContactCursor for Select * from Contact;
end GetallContacts;
here is my delphi code
with OracleQuery1 do
clear;
sql.add ('begin' );
sql.Add (' contact_actions.Getallcontacts (
_ContactCursor )');
sql.Add ('end;');
DeclareVariable ( 'p_ContactCursor', otCursor);
SetcomplexVariable ('p_ContactCursor', CursorQuery );
Execute;
With CursorQuery do
Execute;
While not Eof do
memo1.Lines.Add( Field('lastname') );
Next;
it is not passing the first execute statement..i am just following the example from the direct oracle access 3.4 could you please help me to find what is the error i am doing here
thanks - BM
end GetallContacts;
clear;
sql.add ('begin' );
sql.Add ('end;');
Execute;
With CursorQuery do
Execute;
While not Eof do
Next;
thanks - BM
