Package compile with roles vs direct id grants
ptbarnum
When we use roles to grant access from one schema to another using a role to grant select access to a group of tables verses assigning each schema the select rights, we are unable to compile a package from within the Package editor. If I cut and paste the script from the package editor to a PL/SQL Developer SQL Window it executes fine but from within the package editor I get a "insufficient priviledges to access object" on the table in the other schema. Even if I right click the package and click recompile It compiles successfully.
Any help would be appreciated.
Peter Barnum
Principal Consultant
Apex Consulting Group Inc.
What happens if you run the same "create or replace package" statement in SQL*Plus, under the same Oracle user?
Thanks for the response.
SQL*Plus gives a message that the package compiled with errors.
In the meantime we found a quote in a PL/SQL manual that says a user needs to be granted rights to all tables referenced in a package directly, not through a role, to be able to compile a package.
Can you confirm that for us?
Peter Barnum
