You can only export a result set to a client-side file if it is returned to PL/SQL Developer. You can either execute the SQL statement in a SQL Window and export the result set, or open a cursor parameter in a program unit and call this program unit from the Test Window. In this Test Window you can subsequently view and export the cursor result set.
PL/SQL cannot access the file system on the client.
