LGEAI Developers
Using DOA 4.0.3 and trying to use the OracleScript component. I set up a test button with the following Delphi 7 code:
procedure TFRIA0024frm.btnExecSqlScriptClick(Sender: TObject);
FRIA0024dm.OracleScript1.Execute;
String List Editor has the following:
select count(*) as audit_id
from ri_audits
where ri_audit_id = 62659;
select count(*) as nbr_trans
from edi_transactions
select count(*) as nbr_acks
from edi_acknowledgements
where editrn_ri_audit_id = 62659;
How do I see the output like PL/SQL Developer Command window?
SQL>
AUDIT_ID
1
NBR_TRANS
44
NBR_ACKS
3
SQL>
Thanks in advance.
Bruce
from ri_audits
SQL>
AUDIT_ID
1
NBR_TRANS
44
NBR_ACKS
3
SQL>
Thanks in advance.
Bruce
