OracleMonitor 64bit
Hi Marco,
Just received my new DOA 4.1.3 license for XE2 with the OracleMonitor Pro Option.
I downloaded DOA file and the OracleMonitor 2.1.1 in addition.
I installed both and did a short test, everything works fine as far as 32bit applications are concerned, however OracleMonitor appears to not be able to see the application when compiled as 64bit Version. Is this a limitation of OracleMonitor?
If so, do you plan to provide this feature in future versions?
Thanks in advance
Horst
This is indeed a limitation, we currently only have a 32 Bit version of the Oracle Monitor. We have a 64 Bit version in the works.
Thanks for the quick answer, Marco...
good to hear you're working on it, so i'll be patient and keep checking for news here...
anyway, have a nice day and keep up the good work.
