I recently bought DOA tools 4.1 basic for BCB 4.0 and there are two questions:
1. When I call OracleLogon->Execute() the first time after a interruption of the database connection (killed the session for testing purposes) the connection is enabled automatically without a Log on dialog visible, that means the application is running as if nothing happened. The second and all further times when I kill the session the Log on dialog appears as expected. Is this a bug or a feature?
2. When I select the Monitor in the newly created menu item Oracle there is an error message about needing a properly installed version available. Shouldn't there be a monitor light shipped with the basic version?
Many thanks in advance
Martin
Martin
