Oracle12c and PL/SQL Developer 10
JoeyM
Hi All,
I'm experiencing problems with Oracle12c and PL/SQL Developer Version 10.
I'm able to connect to the oracle 12c database fine. The problem I'm experiencing is when I attempt to perform a select from a table or view a store procedure/function.
The error message I get is:
ORA-12801: error signaled in parallel query server P000,......
ORA-00600: internal error code, arguments[kxspoac: EXL 1].....
Has anyone experienced this error before? Has anyone manage to successfully use PL/SQL Developer 10 with Oracle12c?
Joey
PL/SQL Developer works just fine on Oracle12c. The ORA-00600 error indicates an Oracle Server bug. You should therefore probably contact your Oracle support representative about this error or apply the latest patches to the Oracle12c Server.
Hi all,
I resolved this issue as follow:
1. I downloaded the Oracle12c 32bit instant client for windows
2. In PL/SQL developer 10, I went to Tools->Preferences->Oracle Connection and set the 'OCI Library' path to the Oracle12c instant client I downloaded.
3. I restarted PL/SQL Developer and all worked fine after that!!
Joey.
