Oracle WITH Statement not working
Stella
Hi
The Oracle WITH statement returns nothing in PL/SQL Developer
eg
WITH dual_rec AS (SELECT COUNT(*) FROM dual)
SELECT * FROM dual_rec
Has anyone any ideas what may be causing this?
Thanks v. much
Stella
This is most likely an Oracle Client version issue. The client needs to be 9.0 or later. Earlier versions do not know of the WITH statement.
Thanks Marco for your prompt response.
I'm actually using 10.2. I've came across a similar post on the Web saying it may be an Oracle Home issue. Does this ring true to you?
Stella
It might indeed be a home issue. Can you go to Help > Support Info, press the 'Copy all pages' button on this info screen, and paste this text into an e-mail reply?
